Some background: I installed but did not complete the install of a new Generator head set. On the connector block where the stator wires connect to the controls harness I noticed that there are 2 pairs of jumpers attached. The 2 pairs are both on the same middle 2 posts....piggybacked on top of the stator wire connectors. I do not remember seeing these on the original gen-head. Should I just discard them or.....? Any help will be much appreciated.
Not to bash on you but that is why you either have a diagram, Most can be found online, Make a diagram or take pictures. If you have the make and model of your generator you should be able to either contact the manufacturer or find it online.
