Since I do not have a Surburan this is part conjecture but as I recall it's really two entierly seperate systems in one box.
The 120 volt system consists of the breaker back at your power distribution panel, wire to the water heater A pair of thermostats (primary and hi-temp) Switch and heat element. it has NOTHING to do with the Propane system
Which has a control board. two more T-Stats, and all the gas valves and ignition stuff.
