โJun-05-2014 10:59 AM
โJun-06-2014 02:03 PM
MEXICOWANDERER wrote::B ๐
Pulled out? Musta been some kinda pull force to break a properly soldered lug!
Yeah, I'm pulling your chain Mena ๐
โJun-06-2014 11:37 AM
โJun-05-2014 01:07 PM
KendallP wrote:That is correct good sir. I'm using the wiring configuration here:
Hmm. That DOES sound pretty weird.
Is it safe to ASSume that the charging power was wired with positive on one pair and negative on the other?
SCVJeff wrote:Always good to have some confirmation. I'm betting I would've seen the same thing if I had let the batts wear off the surface charge.
Had that exact problem with the jumper that ties in the 2nd set of 6v. The difference was 1/100v, maybe a little more, don't remember. But it was enough over time to make a noticeable difference in the SG of that battery set, and that's what caused me to pull out the 4.5 digit Fluke and poke around.
โJun-05-2014 11:33 AM
โJun-05-2014 11:17 AM
