Onan 167-1638 Spark Plug Equivalent
_1Flyboy
. . .Hello. . .Looking for an EQUIVALENT to an Onan 167-1638 Spark Plug; if you have an equivalent number where did you get that number? Seems like there are a lot of different cross numbers floating around. . .Would love to get a compatible plug available at a local parts store. . .Thanks in advance!
4 REPLIES 4
_1Flyboy
. . .Found the ONAN 5.5 Marquis equivalent plug is stamped on my new plugs from Onan; they are NGK BPR4EY if anyone is interested!!!!
Kpackpackkelley
Look on your spark plug probably a champion number and then cross that number or use The champion number. Any auto supply will have what you need.
rockylarson
I searched for a sub awhile back and decided to stay with the OEM. It was easier to find and not a long wait.
I see it is about $7 on Amazon with free 2day Prime shipping.
I have used this site for all three filters and plugs: Onan Store
Jan and Rocky
Volunteers for USFWS. 29 refuges with 9300 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
othertonka
Use a spark plug cross reference chart to try and find it, google brings up quite a few, but why not use the original 167-1638 plug found here for about $4.79
Onan spark plug
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
