Onan Marquis 7000 generator
n410mp
My 18 year old generator starts, but won't run. If I manually play with the throttle linkage I can get it to run for a few seconds after starting, but that's it. If I do nothing, as soon as the engine fires the starter kicks out (correctly) and the engine dies. Air and fuel filters are clean and it's getting both. It used to start and run fine, then one day suddenly decided IT was going on vacation. Any suggestions?
5 REPLIES 5
RedG
Is this a gas genny or a diesel? If gas, has it been sitting a long time? If so, you may have a gummed up carb.
2005 Newmar Dutch Star 4024 DP 370 Cummins
Towing my 2012 Malibu w/Blue Ox towbar & Patriot brake system
gunny357
Suggest you post the complete model/serial/spec numbers so we'll know what you have.
I ain't so good at guessing anymore.
Tom_M1
Here's a link to download an Onan troubleshooting guide:
http://www.flightsystems.com/pdf/onan-rv-troubleshooing-guide.pdf
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
MEXICOWANDERER
Short the terminals on the oil level switch to test.
TEXAS
How is the oil level.
