Outside storage door
Planedenn
The outside storage cubby hole door on my C class is rotting out. Are there any used parts or salvage yards in Canada, preferably Ontario? Camper is a 1983 I don'really want to spend a lot of cash.
3 REPLIES 3
MrWizard
Moderator
Moderator
I've done several on different RV even did two entrance doors
Plywood and sometimes 1*2's (entrance doors)
Most are made with press board, which doesn't bode well if it gets wet
Assemble with A good plywood of the correct thickness and all is well
I can explain it to you.
1997 F53 Bounder 36s
Planedenn
I thought about that. Maybe a good day project project this winter.
It's just plywood. I have a table saw and glue
Son_of_Norway
I have a similar problem with the door to my generator compartmant. My plan is to take off the inner and outer skin of the door, install new wood, then put the door back together. Maybe this would work for you.
Miles
Miles and Darcey
1989 Holiday Rambler Crown Imperial
Denver, CO
