โJun-13-2014 04:47 PM
โJun-15-2014 10:43 PM
mena661 wrote:BFL13 wrote:Always wondered why you switched from that setup.
So after all that we are back to where we were three years ago when I found out that 210w was perfect for us. Got to stop fixing things that ain't broke!
โJun-15-2014 09:02 PM
โJun-15-2014 05:37 PM
โJun-15-2014 05:33 PM
Almot wrote:JiminDenver wrote:
the heaviest 12v load we have is a 12v, 200w, auto drip coffee maker. Running it along with the furnace, lights and fans might pull the system out of float.
Right now I am using a 3000w PSW inverter but plan on a smaller one for just the TV and dish. The draw at idle on the big inverter is crazy high.
Without self-aiming gizmos in sat system, 300W should suffice. Definitely will, if you switch to stove-top coffee. Or - tea. Lights you normally don't need - too much - at the same time with solar charging.
โJun-15-2014 04:56 PM
westend wrote:
With this talk of two controllers, it raised a question: Is there any problem with connecting two controller outputs to the same pair of wires and then leading that pair to the batteries?
โJun-15-2014 03:24 PM
โJun-15-2014 03:10 PM
โJun-15-2014 09:31 AM
โJun-15-2014 09:03 AM
RoyB wrote:
I'm having a bad feeling that once I get behind the charge state curve it will be hard to keep up without having to run the generator some to start off with.
Roy Ken
โJun-15-2014 06:18 AM
โJun-14-2014 09:28 PM
pianotuna wrote:
Hi Jim,
16 amps at idle? wow that's a LOT. Or is that a typo?
โJun-14-2014 09:23 PM
mena661 wrote:
Jim, do you have a picture of it?
โJun-14-2014 09:07 PM
โJun-14-2014 08:23 PM
โJun-14-2014 08:20 PM
