โAug-07-2021 07:37 PM
โAug-08-2021 05:56 PM
wa8yxm wrote:
I would go with a pole mount on the ladder... Put it up and peak it .. Then return to ground.. take it down to move....
Three As I recall those antennas need to be | not /
Polarisation diversity
To take full advantage of MIMO, (currently used in 4G LTE communications), two antennas must be used.
When installing directional antennas like a Yagi antenna, the first antenna must be rotated horizontally to a 45 degree angle and the second to a 135 degree angle. This is because of "polarisation diversity".
LTE uses polarisation diversity to help distinguish between the two data streams sent from the tower.
โAug-08-2021 05:48 PM
pinesman wrote:Dutch_12078 wrote:
Here's how I mounted my twin Yagi MIMO antennas above my batwing OTA antenna:
I had thought about something like that but I was afraid the yagi antenna and inside antenna would be too close together to work properly
โAug-08-2021 10:38 AM
โAug-08-2021 04:49 AM
โAug-07-2021 08:09 PM
