โApr-17-2021 04:57 AM
โApr-19-2021 08:15 PM
โApr-19-2021 06:06 PM
โApr-19-2021 04:16 PM
Roger10378 wrote:
Most likely you will have flare fittings to hook to. Never use sealant on flare fittings. If you have threaded fittings then you need sealant.
I would observe the line as the slide is moved in and out to see if a slightly longer or shorter hose would be less likely to kink. Then take the hose with you to your local propane dealer to have the hose you need made.
โApr-18-2021 05:59 PM
โApr-18-2021 06:46 AM
โApr-18-2021 06:32 AM
โApr-17-2021 07:51 AM
โApr-17-2021 07:41 AM
โApr-17-2021 07:31 AM
