โApr-01-2016 06:28 PM
โApr-04-2016 05:14 AM
โApr-03-2016 10:17 AM
eHoefler wrote:
Believe it or not, grey water can and will produce methane gas. And can smell as bad or worse than a black tank, most black tanks get some kind of treatment for odors.
โApr-03-2016 07:01 AM
โApr-02-2016 07:33 PM
Rollnhome wrote:
So I understand this vent is for the grey tank as well as the sink. In other words this will vent the entire grey water system.
โApr-02-2016 08:28 AM
โApr-02-2016 08:07 AM
Bobbo wrote:
Gray water smells as bad as black water. I don't think you have the methane gas though.
An idea. The vent pipe does not have to be straight. How about running it up into the ceiling, putting a 90 degree elbow, and running it to an area of the roof that is not covered by the roof rack. Then put another 90 degree elbow, and take it up through the roof there?
The plumbing vents in my S&B house have all kinds of elbows and lateral runs.
โApr-02-2016 07:57 AM
gbopp wrote:
Here's an option recommended by another forum member. VENT
It's also recommended to use a setup for a garbage disposal to connect to the line and use a rubber hose to the vent.
โApr-02-2016 07:40 AM
โApr-02-2016 07:38 AM
evy wrote:
Maybe I forgot to mention this, we're talking about grey water only. I have a porta potti ๐
In this case it will serve to let air out when the tank is filling up, preventing a gargling sound through the drain pipe.
Is grey water as bad as black water for gases and oders?
โApr-02-2016 07:15 AM
โApr-02-2016 06:26 AM
eHoefler wrote:
The Air-Admittance Valve will not work as a vent, it lets air in so your sink will drain properly. You have to have a vent that will let the gases from your tanks out. The reason you need to have a vent higher than the roof line, is so any breeze can catch it and carry it off. On the side, it can pool and you will not like the aroma, plus sewer gas is deadly and explosive. Any vent, window, or appliance will bring in the gas.
โApr-02-2016 05:56 AM
โApr-02-2016 04:32 AM
โApr-01-2016 09:44 PM
buzzard616 wrote:
Goofy as it sounds, the longer I think about it and try to think of anything better, that tub overflow looks like it should work. Maybe drop the rubber gasket in favour of some butyl-based caulk or window tape.
Stu
