Previous post on generators
rving4us
I posted a few weeks ago about using my champion generator, and several got upset that this subject had been discussed several times, so this next question is directed to the ones that actually have experience with what I'm asking, others don't bother. Since the non inverter type was deemed to noisy I started researching the inverter type. Honda has the 2000 that can be combined with a like kind to produce 4000 watts. The champion also has the same set up with inverter type generators. Having known people that had problems with the Honda not stating after sitting all summer, and knowing my champion will start easily. I tend to think the Honda is name only. Also, the Honda is $999.00 each and the champion are $675.00 each.
Finally the question will the champions give the same power and perform as well as the Hondas, and are just as quite? I have heard the Hondas run, but not the Champions.
Thanks
Cary
2014 Ram,4x4,dually,CC, Cummins, Aisin Trans, 4:10 rears
2011 Carriage Cameo37ks3,17.5 tires,disc brakes,full body paint.
30 REPLIES 30
1492
Moderator
Moderator
Moved from Technology Corner
