Problem with AGM Batteries
La_Gasser
I have a 2017 Jayco Seismic Wave Toy Hauler with the original 2 Interstate AGM batteries which are now 4 1/2 years old. It seems that the batteries are not holding their charge as long when not plugged into shore power. I've had it off shore power for 1 day with the Battery Cutoff switch not on, meaning batteries are still connected. Volt Meter shows around 11 volts, but when you turn the Battery Cutoff switch on, the reading is 12.5 volt or approx 80%. If you activate the landing gear switch while the Battery Cutoff switch is on, the reading goes from the 12.5 down to around 10.7 volts. Seems to me that the batteries are just holding a surface charge when at rest, but when you put a load on them, they are shot. Does that seem right to y'all? Thanks
16 REPLIES 16
time2roll
Post the converter model number. Good chance they have been under charged. You really need to get these up to 14.4 volts.
Considering the low voltage it is probably best to separate the batteries for testing.
Ed_Gee
Sounds about right to me. You could try an equalize charge but probably won't do any good in my view.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
