Apr-21-2018 08:34 AM
Apr-24-2018 08:37 PM
MEXICOWANDERER wrote:
Picked up a 345 watt panel today which should apply enough amperage to properly charge the 2 Trojan T-105 AGM's.
Picked up a 345 watt panel today which should apply enough amperage to properly finish charge the 2 Trojan T-105 AGM's.
Apr-24-2018 07:51 PM
If you have a 6 lane to one lane freeway bottleneck amperage because of too small of factory wiring you will be an unhappy camper.
Apr-23-2018 06:24 PM
Apr-23-2018 06:22 PM
Apr-23-2018 06:20 PM
Almot wrote:Rail Dawg wrote:
... I'm going to have roughly 350 watts at 24 or 36 volts going into a dual Trojan T-105 AGM 12 volt battery bank.
No, you are not 🙂
If bank is 12 volts, controller will detect it and will push only ~13 volts.
MPPT will convert high voltage of panels into lower volts and higher amps.
A=W/13V, so 350W will get you about 25A max, after all the losses.
Apr-23-2018 01:28 PM
Apr-23-2018 10:20 AM
Apr-23-2018 07:57 AM
brulaz wrote:My MC4 wire is rated 600 volts. And yes you can get a controller rated 600 volts input.
Watt limitation on solar wiring? I've only heard of the 30A limit on 10ga and 20A on 12ga. Always presumed that was good up to 100V, the usual mppt limit.
Apr-23-2018 07:54 AM
Rail Dawg wrote:The controller will limit power to 30 amps.time2roll wrote:
You only need a larger controller if you have more solar wattage.
Dumb question then can I double my solar wattage to say 36v 700 watts and still use the MPPT 100/30 controller?
Thanks.
Apr-23-2018 07:05 AM
brulaz wrote:At different voltages, yes.
Apr-23-2018 05:56 AM
2oldman wrote:Rail Dawg wrote:I'm not sure there is such a thing. In my case it was determined by the #10 wires from the roof to the basement. They will max out at about 360w at 12v. I have 835w.
What is the recommended voltage for the solar panels?.
Apr-23-2018 04:50 AM
Apr-22-2018 10:01 PM
Apr-22-2018 09:38 PM
time2roll wrote:
Yes that 355 watt panel feeding a Victron 100/30 will put up to 30 amps into your battery.
Sheet says up to 440 watts so get a little bigger is OK too.
