Propane changeover valves
mchero
I have been running an external 100lb tank for my propane. One tank on the high pressure side. I'd like to install an LP automatic changeover valve so that I can run two tanks. I will first have to move the external connection over to the low pressure side.
I'm just not familiar with the different valves available.
I don't want to get a chepo valve. I'm asking users what valve I should consider. I will be running the stove and two atwood furnaces.
Thanks
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
3 REPLIES 3
Edd505
mchero wrote:
Thanks ever so much Biscuit! Really appreciate ALL your posts on this forum. You and Doug are the best!
Very likely the most knowledgeable person on the site, always top notch info.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
mchero
Robert McHenry
Old-Biscuit
Cavagna 924n 2 stage auto changeover Regulator
Both tanks would connect to regulator High Side
Regulator then controls pressure/flow to RV LP System
YES....:LP Line connection to your RV from Tanks/regulator should tie into RV LP SYSTEM downstream of your RV Regulator
*2 LP Regs in series does not work
*Might sure you install shutoff valve at connection so RV tank/external tank systems can be isolated from each other
