Propane tank replacement options?
mcewena
My 2006 era Manchester side mounted tank (86157) is at end of life. It wonโ€™t pass a recertification. Just wondering what my options are for replacement. Similar sized tanks on the interweb arenโ€™t cheap and the mounting attachments look different as well. Some have suggested replacing it with a pair of 20lb bbq tanks but Iโ€™m concerned about the angle and and Iโ€™d have to have a bracket fabricated.
2007 Winnebago View.
Thks
20 REPLIES 20
mcewena
Dutch_12078 wrote:
A rack fabricated to hold two or three 20 lb BBQ cylinders upright could work using an automatic switchover regulator setup.
Can they be used/stored/transported on their side or 45 degrees?
mcewena
dougrainer wrote:
USA ASME tanks are not required for certification. Are you POSITIVE, that Canada requires ASME certification and not just DOT portable tanks which DO require recertification? Doug
Iโ€™m positive that some fill stations wonโ€™t fill my tank. Thatโ€™s what matters in the long run.
Canadian regulations are hard to pin down but I talked to a local propane recertifier and he said he probably wouldnโ€™t pass mine due to the rust so I know Iโ€™m on borrowed time with it.
mcewena
IB853347201 wrote:
Have you contacted Winnebago? you can probably order a replacement tank thru them.
Yes and itโ€™s north of $2k, thatโ€™s why Iโ€™m looking for options.
dougrainer
Dutch_12078
Dutch
2001 GBM Landau 34' Class A
IB853347201
2010 Suncruiser
