Propane tank replacement options?
mcewena
My 2006 era Manchester side mounted tank (86157) is at end of life. It won’t pass a recertification. Just wondering what my options are for replacement. Similar sized tanks on the interweb aren’t cheap and the mounting attachments look different as well. Some have suggested replacing it with a pair of 20lb bbq tanks but I’m concerned about the angle and and I’d have to have a bracket fabricated.
2007 Winnebago View.
Thks
20 REPLIES 20
mcewena
Dutch_12078 wrote:
A rack fabricated to hold two or three 20 lb BBQ cylinders upright could work using an automatic switchover regulator setup.
Can they be used/stored/transported on their side or 45 degrees?
mcewena
dougrainer wrote:
USA ASME tanks are not required for certification. Are you POSITIVE, that Canada requires ASME certification and not just DOT portable tanks which DO require recertification? Doug
I’m positive that some fill stations won’t fill my tank. That’s what matters in the long run.
Canadian regulations are hard to pin down but I talked to a local propane recertifier and he said he probably wouldn’t pass mine due to the rust so I know I’m on borrowed time with it.
mcewena
IB853347201 wrote:
Have you contacted Winnebago? you can probably order a replacement tank thru them.
Yes and it’s north of $2k, that’s why I’m looking for options.
dougrainer
Dutch_12078
Dutch
2001 GBM Landau 34' Class A
IB853347201
2010 Suncruiser
