Radius External Battery Door - Can I get a new one made?
ZRX-Steve
I have lifeline AGM batteries that don't have to be in a vented compartment. The battery door has a 2" wide perforated vent strip running vertical from top to bottom. Since I don't need the venting, I'd prefer to have a fully insulated door to keep the batteries warmer and extend their performance.
Can I get a new insulated door without the vent?
Lance 1191
2014 Lance 1191, 00 F350 DRW, 7.3, Auto, aftermarket intake/exhaust/transmission (pan, cooler, valve body),Gauges, PHP Hydra Chip. Supersprings, HD Timbrens, Sumosprings, Front+Rear 1.5โ€ Swaybars, Monroe Gas Magnum Shocks, 19.5" Vision, Centramatics.
5 REPLIES 5
westend
If the battery compartment is unheated or not influenced by any conductive heat transfer from another part of the structure or the sun, the battery compartment will be at ambient temperature whether you seal the compartment or not.
'03 F-250 4x4 CC
Francesca_Knowl
That's the number nine entry at the following link: Common Battery Myths.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
MEXICOWANDERER
Line the inside with 20 gauge aluminum but a MALFUNCTIONING VRB can and will vent hydrogen and oxygen. Oh what a perfect thermobaric bomb that compartment would make. Want to get to Quartzite in 10 seconds flat?
We_Cant_Wait
I'd be a bit cautious of sealing off the battery compartment even with the AGM batteries. While they don't out gas like regular batteries there is still a bit of out gas going on. If there wasn't the batteries would bulge and possible break open.
beemerphile1
If you're handy you might just dismantle the door and install a solid panel.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
