Recovering bench seat cushions and window covering
anniendan
In our Arctic Fox we will be recovering/reupholstering the dinette cushions. The bench seat is actually two cushions with a zipper separating the two cushions. Yet they are a complete unit on the bench. Has anyone ever reupholstered this type of setup?
Also would like to change the fabric on the window covering at the top of each window. Not sure how these are attached. Anyone have a clue?
Thanks in advance.
1 REPLY 1
trop-a-cal
Use the old covers for a pattern for the cushions. The window material may be on by glue or staples. Usually you have to take them down and cover then as you can't get the new material on with them still up on window. Sometimes the old material has to come off as with two layers it's possible they won't fit back on the attachments as space is tight.
