Refrig not cooling but freezer is
carlandpat
Had this happen before and someone suggested the slide on the fins in the upper part of the refrigerator had been moved. It fixed the problem but now I can't remember if it is to be up or down? The freezer is cooling fine.
5 REPLIES 5
dougrainer
Golden_HVAC wrote:
Hi,
How long did you let the refrigerator run?
Was it on gas or electric?
How hot is it outside?
If you have been letting it run on gas more than 7 days, then how hot it is does not really matter.
If it is on electric, even if the refrigerator started out cold, it might warm to as much as 45 or 50F on a 90F day outside, because the cooling unit is only running at about 50% while on electric.
The typical burner is 2,200 Btu's per hour, with about 20% going up the flue, that still leaves about 1760 into the boiler. The typical electrical element is 300 - 320 watts, with 3.4 Btu's per watt, or around 900 Btu's.
On 12 volts, typically they can draw about 15 to 25 amps, or close to 150 - 300 watts, depending on how large the wire is and what voltage is actually applied to the heating element.
So if you let it run overnight, I am guessing that if on gas it might cool down properly.
Fred.
LP or 120 the BTU's are identical. The RV refers will cool identical regardless of Heat source. I do not know where you guess that the 120 is at 50%. NOT TRUE. The design of the Heat Source is identical. The 120 will actually heat the flue better than a flame. They have to install a spiral baffle in the flue to disperse the Flame heat evenly around the flue to get LP flame BTU's to heat correctly. NO RV REFER will cool on 12 volt ONLY (3 way models). The 12 volt on 3 way is a Maintainer of existing temp in the refer for operation while in transit. 3 way 12 volt operation are in transit operation ONLY. Doug
Golden_HVAC
Hi,
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
1492
Moderator
Moderator
Moved from Forum Technical Support
midnightsadie
you should check your frig door gasket , mine did like yours I put a bungee cord across it now I can freeze the milk.
Old-Biscuit
IF you can not adjust temp setting on upper control panel then moving thermistor will make minor adjustment 6*-8*F
On a non-adjustable moving thermistor UP for cooler temp and DOWN for warmer less cool) temp in food section
Dometic has markings in food section
What temps are you getting in freezer and in food section??
