โMay-09-2016 12:30 PM
โJun-06-2016 06:59 AM
โJun-06-2016 05:30 AM
Chris Bryant wrote:
Some Dometic models have no thermocouple, but if yours does, testing is easy- just measure the voltage it puts out in the flame. For the non-integrated igniter boards, the thermocouple needs to put out above 15 mv, with ~25-30 mv being the norm.
For the integrated igniter boards, where the spark wire goes right to the main board, there is no thermocouple. Flame sensing is done purely through the electrode and flame itself.
Sounds like a tax deductible vacation to the high country is called for ๐ (I grew up in Colorado).
โJun-06-2016 05:12 AM
wgriswold wrote:
Some people have reported that leaving the cover off during operation increases the availability of air and helps at altitude.
What color is the flame at altitude?
โJun-04-2016 08:07 AM
โJun-04-2016 06:16 AM
โJun-03-2016 01:31 PM
stevenal wrote:
I recommend the Dinosaur Electronics replacement boards if you get to that step.
โJun-03-2016 12:54 PM
d-mac1 wrote:
Cleaning it didn't fix it. I was at around 9k last weekend and same problem. Here is what it does when trying to run on propane and the problem arises when it tries to light.
It'll light, but it will keep sparking the ignitor (even though I can hear it burning). It'll continue to spark the ignitor and after a short while, it'll stop sparking it and I think it then closes the gas valve, so the pilot goes out. Repeat, repeat, quit.
I've got the wind covers off again and thinking the probe that sticks into the flame must need to be lowered or something. Its the only thing I can see that senses temperature (ie.. that would tell the unit that the flame is lit...but if this is the problem, why the flame isn't as hot at higher altitude is a bit of a mystery to me.
โJun-03-2016 12:23 PM
โJun-03-2016 12:12 PM
โJun-03-2016 11:39 AM
โMay-13-2016 02:52 PM
d-mac1 wrote:wa8yxm wrote:
I think your dealer is speaking through his hat, but there is an air/fuel adjustment that may need to be opened up a bit at high altitude. you need to learn how to adjust it.
Also a full PM run on the Fridge.
Can you please clarify? How do I adjust it and what is a "PM run on the Fridge"?
โMay-13-2016 02:47 PM
โMay-10-2016 08:06 AM
โMay-09-2016 05:37 PM
d-mac1 wrote:
I've got a Dometic 2852RBX that works ok most of the time, but when I had it at 9,750' last year it kept going out and wouldn't relight. It would try, but I'd come back after being gone for awhile, or awaken in the morning, and the check light would be on.
My dealer said its the orifice size that needs to be changed for high altitude and said to talk to Dometic technical support. I called and was not happy with the level of 'support' I was provided. Among some curt responses, I was told they aren't guaranteed to run at over 5,000'...NO further help! I live near Denver....EVERYTHING is above 5,000'!!
I continued to try to get some information on what size orifice would make it work at altitude to no avail. Finally the unhelpful phone rep went to ask 'the boss' if it can even be changed on my fridge and when she came back on the phone she told me NO...I can't change the orifice in my unit. I just looked and yes it can be changed. It has a 53 in it now.
Since the problem occurs at high altitude, less air pressure, I'm guessing (if this works like a carburetor) means I need less propane, thus a smaller orifice (or jet if you will).
Does anyone know if I'm on the right track so that I can keep my fridge running next trip up there? If I could get the right sized orifice, my thoughts are to take it along on a trip and if problems, put it in until returning to lower altitude.
In case you are wondering, I was at my dealer because I was guessing the problem was a faulty regulator, but they said thats not the problem if it works fine otherwise.
Thanks.
โMay-09-2016 05:21 PM
