Refrigerator shuts down in transit during windy conditions.
Desert_Reign
Any suggestions on preventing the refrigerator from faulting off during windy conditions while in transit? It does fine normally, no problems sitting still, only when traveling in windy conditions. Thought about covering the vent, but thought about getting some input first.
3 REPLIES 3
RJsfishin
Its normal,.....or common. You can mess w/ shrouding/shielding etc, but otherwise we live w/ it. Just remember to fire it up during lengthy stops.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Old-Biscuit
Fridge propane being blown out while in transit is due to 'body design' creating turbulence along the side of rig.
Usually hear about this with truck campers and Class C due to 'camper' being wider than cab.
Sidewall of travel trailers and 5th wheels is relatively smooth and air flows down sidewall without swirling.
Running with fridge on is perfectly safe. They are designed to operate while in transit....with features to shutdown safely.
Normal hwy speed isn't the issue.......windy conditions are and not much you can do to control winds
Blocking off lower vent will just result in less cooling due to obstructed air flow (draft effect).
You could install a sheet metal shield like the Dometic Recall Kit around burner area.
old_guy
best to run with it off.
