โApr-29-2013 10:49 PM
โMay-02-2013 05:31 PM
โMay-02-2013 03:15 PM
Do you think that the PD would be a good replacement for the WF converter??
โMay-02-2013 01:04 PM
bigfootford wrote:ken burke wrote:Wayne Dohnal wrote:
At a typical 80% efficiency and 0.7 power factor, a maxed-out 60 amp converter will draw over 1,500 VA, and a maxed-out 75 amp converter over 1,900 VA. You can get away with higher than 60 amps on an eu2000i if you're willing to make sure the battery doesn't get highly discharged, cut other loads when necessary, and/or manually kick the converter out of boost mode when necessary. If you really need the bigger converter, a power factor corrected model might be justified.
Thanks . . . . good info. I am not sure, but I think that you are saying to get the 70-75 amp converter.
How do I manually kick out the boost mode on a converter? Is that a special option on some converters?
We don't boondog much, but I have a Harbor Freight 3000 generator, and I plan on doing some boondogging where I will need to use the generator.
I went through Bend 40 years ago, and fell in love with it. I remember one gas station and one diner. A guy at the diner said he shot a buck off of his porch. I returned to Bend 15 years later, and decided to look elsewhere.
ken
The PD "Progressive Dynamics" product line is the only moderate cost converter that provides this ability. In my and many's opinion one of the best features avail for charging our batteries.
Sometimes when one starts charging and the batteries are cold they will cause all converters to not go into Boost/bulk mode. Thus charging will be slow. If one has the PD with the controller he can switch modes to bulk by pushing a button.
Another is if you have a big battery bank and a high amp converter 60+ and are trying to charge using a smaller genny you can switch modes to a lower charge rate, ABSORB or Float until the batteries have charged enough to allow the higher charge rate of bulk mode.
Another is when your batteries are hot 95deg+, because of hot weather . You do not want to charge very long in bulk mode with any converter. The PD allows you to switch modes to a lower setting and thus not boil your batteries.
Jim
โMay-02-2013 11:13 AM
ken
โMay-02-2013 10:14 AM
renoman69 wrote:Renoman's experience is the perfect example of why I stopped guaranteeing and promising. Sometimes things just work out differently.
whatever....I have watched my Iota 75 put 73 amps into the 50% battery bank while being powered by my Honda eu2000i.
โMay-02-2013 09:40 AM
โMay-02-2013 09:08 AM
โMay-02-2013 08:29 AM
โMay-02-2013 04:56 AM
ktmrfs wrote:
The PD units are IMHO a definite improvement over the WFCO units. WFCO are not known for going into bulk mode charging for most users.
If you dry camp and use a 2000W or smaller generator, I'd recomend the PD60A unit over a bigger one. The reason is that the 60A is already near the max continous rated VA for many 2000W generators. The actual current draw is near 1500VA (much higher than the watts, related to the poor power factor) when charging well discharged batteries. The 70A unit may push you over the edge with a 2000W generator, especially at higher temps and high altitude.
If your not "generator" limited, go for whatever will fit.
โMay-01-2013 11:00 PM
โApr-30-2013 09:55 PM
โApr-30-2013 09:35 PM
โApr-30-2013 10:03 AM
โApr-30-2013 05:40 AM
