Chatting at a CG a few weeks ago got me curious. A fellow camper said just in passing that his wife was fussing because the radio reception was weak and he needed to get up on the roof and raise the antenna.
I've never really paid any attention to ours 'cause it is just there so to speak. So I got the ladder and went up to take a look. It turns out that ours is spring loaded, and as it has hit limbs etc over the years it has been slammed into the rubber roof. UH OH lots of little dimples that may or may not have been punctures about 1/16".
I also found a small tear nearby that wasn't there 3 weeks ago when I replaced a vent cover. Lucky timing going into the winter on that one. I had to order some eternabond for the 2 areas but in the interim it turns out that Gorilla duct tape will hold as an emergency patch even at speeds up to 50. Be careful pulling it off so you don't make the hole any bigger.
I tied the antenna in a knot to avoid any future damage and I'll probably just snip it off one day when the wind isn't blowing 30-40 like it was yesterday. It even blew the ladder down once.
Puma 30RKSS
