I'll try that next time. I cleaned mine with carburetor cleaner in a spray can.
This because the rack gear teeth had some goo at the bottom of the u-shaped on each gear.
The Schwintek video shows them using a bent straw on the CRC can to spray the gear block behind the exterior seal. What's up with that?
The CRC is not a true dry lube. It has some sort of liquid lubricant as far as I can tell.
A true "dry lube" would be graphite - which is available in a spray can. However, it is black and not pretty.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap OwnersโThe best lack all conviction, while the worst
Are full of passionate intensity." -
Yeats
