SLIDEOUT ELECTRICAL MYSTERY!!!!!
joelyn
I will explain a situation that happened today and see who knows the answer... putting in a new tv in our 04 TT with one slide. cutting a hole w/ a power hole saw through a cabinet to run the cord. went through like butter. went to take the saw off my drill and inside the hole saw was some chewed up wires. OH S.... go and look and i ripped a apart a black and white wire 10 gauge.
Checked all breakers and fuses and NOTHING WAS TRIPPED. no sparks when i cut the wires in 2, NOTHING. turns out that the wires were to my slideout switch since that is the only thing that wasn't working. Wasn't sure if the slide out was run by 12v or 110v so i took out my meter and checked the 4 wires and got no reading for any type of electric, so i assumed that a inline fuse somewhere was burned out.
had to remove some more of the wall and was able to get to the wires and was able to reattach the 4 wires with a small jumper wire and spade connectors.
so i figured that it was now time to start searching for the inline fuse. but for the heck of it i went over to the slideout switch and pushed it and bingo the slide out was working again.
SO MY MYSTERY IS, HOW DID NOTHING BLOW OR ARC WHEN THE 2 WIRES WERE BROKEN AND TOUCHING EACH OTHER AS WELL AS THE METAL SAW. MY METER SHOWED NO READING AT EITHER WIRE END FOR 12V OR 110 AND NO BREAKER OR FUSE BLEW IN MY PANEL? YET WHEN I REATTACHED THE WIRES THE SLIDE NOW WORKS. ANY IDEAS??????????????????/
THE TT IS A 2004 KEYSTONE 30 AMP CORD AND THE TT WAS PLUGGED IN AT THE TIME AND MY A/C WAS RUNNING AND NEVER STOPPED AND ALL OUTLETS WERE STILL ENERGIZED. THANKS
19 REPLIES 19
Dutch_12078
Slide switches commonly have 5 wires attached, 1 that supplies 12-volts, and 4 that go to the slide motor/brake assembly. None of the 4 that go to the motor are "live" except when the switch is pressed. Most likely in your situation, the wire supplying 12-volts is routed separately from the other 4 wires.
Dutch
2001 GBM Landau 34' Class A
Mandalay_Parr
The wires may have been between the switch and motor.
Therefore, no power until switch is activated.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
westend
The hole saw is an intermittent contact and there may not be any power to the slide motor until switch is engaged. I'd bet it would be hard to blow a fuse if you tried. BTW, slides are typically powered directly from the battery. There should be a fuse close to the battery for the slide.
'03 F-250 4x4 CC
EV2
Best guess would be that wires are only carrying 12 volts while the slide switch is being pressed.
MEXICOWANDERER
"go and look and i ripped a apart a black and white wire 10 gauge"
Could it be...?
The wires play possum...?
Until the switch is thrown...?
