โAug-23-2013 01:08 PM
โAug-24-2013 04:42 PM
westend wrote:
I'd have to break down the 8 battery bank into a more usable configuration. In fact, if pulling them all to do at home, each would be treated individually.
Since we can't measure with a hydrometer, measuring volts and current would be our tool.
Most AGM mfg's have a equalization or capacity recovery voltage listed for this purpose. I know mine is 15v. I would first charge the battery as usual and have an observable baseline voltage at full charge. I would discharge the battery with a purely resistive load like a heater, dummy load, or light. I would observe the time it took to reach a low voltage setpoint, that might be 12.0v. I would then charge the battery as per usual until full and then charge using the capacity recovery voltage. The battery would be drawn down again, to the low voltage setpoint and time observed. If the equalization/capacity recovery was successful it should take longer to reach that setpoint.
A SOLID "A"
Passing grade, Mex? I'm sure there is a better way but that's what I come up with.
โAug-24-2013 04:36 PM
MNtundraRet wrote:
You have to remember that That most people could "care less" until Murphy's Law happens. Then they come :h and ask for help. :B
MNtundraRet wrote:
Besides most of us are camping now. A technical question like this works best in the early spring when most of us have "cabin fever" and are waiting for Winter to end. ๐
โAug-24-2013 06:51 AM
โAug-24-2013 05:29 AM
MEXICOWANDERER wrote:Desulfation and equalization are two different processes. You equalize wet cell batteries to distribute the acid equally within a cell. You can not equalize an AGM or gel battery. Here's an excerpt from a Deka battery document:
AGM batteries can sulfate just like any other lead acid battery. Other than by Ouija Board how would YOU determine if a battery has become sulfated and how severe is the sulfation, and if desulfation (equalization) has been done properly.
โAug-24-2013 01:38 AM
โAug-24-2013 12:01 AM
โAug-23-2013 09:10 PM
โAug-23-2013 06:32 PM
โAug-23-2013 06:13 PM
If I could "care less" about something I ignore it. Threads, conversations, remarks, and opinions. This isn't about the subject matter merely the stated level of disinterest in the subject.
โAug-23-2013 04:17 PM
โAug-23-2013 04:09 PM
TechWriter wrote:Double ditto.RJsfishin wrote:
I couldn't care less.
Ditto.
โAug-23-2013 04:04 PM
โAug-23-2013 04:01 PM
โAug-23-2013 03:54 PM
โAug-23-2013 03:20 PM
