Solar wasted watts/volts
starcraft69
I am curious what happens to the watts /volts when your system is fully charged and you have no demand? Were does the extra power go?
2007 chevy 2500 HD 6.0 longbed
2015 Eagle HT 28.5 5th wheel
tucker the fishing dog
45 REPLIES 45
Harvey51
time2roll wrote:
Harvey51 wrote:
Anyone got an explanation for what Ontario Hydro does when itโ€™s heavily subsidized solar panels produce too much power? They give it to their good neighbours in the northern states, and sometimes pay those power companies to take it. I suspect it is due to deals made by politicians that require the utility to buy all the solar power available at prices 5 to 10 times the cost of other power sources.
Have a link to this issue? I believe there is more to the story.
Toronto Sun story
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
Rice
Almot wrote:
Though I don't see how this is related to perceived "problem" of excess power (that is not really a problem, as many have noted).
It's not a "problem" (the OP's concern), but it is an opportunity
Almot
pianotuna wrote:
Some of the top of the line controllers do have voltage sense wires.
I would say that most top of the line controllers have voltage sense. Morningstar MPPT (at least, those 45-60A). Rogue 30A MPPT have it - or had, before going out of business, couldn't compete with $2/hr Chinese labor. For controllers 30A and higher this is a must to have.
Though I don't see how this is related to perceived "problem" of excess power (that is not really a problem, as many have noted). Voltage sense is to prevent voltage drop from affecting the voltage setpoints on battery terminals. Then controller brains would do their job, adjusting the absorption time and/or other parameters according to battery state of charge. Diversion doesn't have to be a part of this. One could use a diverted energy to heat the water, not big deal to me, it's not too cold and propane works well.
Rice
mike-s wrote:
How does that circuit adjust to allow the batteries to reach absorption and equalization voltages and times so they're properly charged and maintained?
We have a relatively-fancy solar controller (Midnite Classic) that has a optional mode where it sets an auxiliary output signal once it reaches FLOAT stage. We have that control signal connected to a solid state relay which then turns the AC power to the water heater on or off.
Further, the controller will pulse width modulate that signal very rapidly, such that the on/off ratio is proportional to only the amount of "excess" solar input (if any), thereby maintaining a proper float voltage at the batteries.
Pretty slick, but the key is a smart enough solar controller that implements this kind of diversion mode.
pianotuna
Nomad II
Nomad II
mike-s,
The only measurement that can be taken is voltage. Some of the top of the line controllers do have voltage sense wires. If mine had that ability I would certainly use it.
Regards, Don
mike-s
Rice wrote:
When batteries are in FLOAT mode, they need very little electricity to keep them floating. We divert that excess solar production via the use of a solid state relay that turns the water heater on and off depending on the battery voltage.
Rice
starcraft69 wrote:
Ok forget the hot water part If i put a over size system in how does the system dissipate the extra power being generated?
I noticed you edited out your question about using the excess for hot water, but you shouldn't have. It can be done.
But first of all, the water heater has to be on the inverter circuit, and I believe that most RVs aren't wired that way. But we changed ours to the inverter circuit just so we could use it on solar.
(But I'll note that our inverter circuit is 30 amps, and when on shore power, it's very easy to go over that if you're using the microwave, water heater, and a hair dryer at the same time. That's probably why the water heater is usually not on the inverter circuit--that, plus most people would never run their water heater off their batteries, so it never needs to run through the inverter. So it's not hassle-free for us to have the water heater on the inverter circuit.)
When batteries are in FLOAT mode, they need very little electricity to keep them floating. We divert that excess solar production via the use of a solid state relay that turns the water heater on and off depending on the battery voltage. When the battery voltage is high enough, the water heater comes on. As soon as the water heater pulls down the battery voltage, it turns off. Over and over and over, dozens and maybe hundreds of times a second, without drawing anything from the batteries.
You can, of course, just turn on your water heater (if it runs through the inverter), but if it draws more than the sun is giving, the water heater will draw down your batteries. Plus you could forget that it's on. Our method automatically "turns off" when there's not enough sun to operate the water heater and keep the batteries fully charged.
However, we have 1,050 Watts of solar, compared to the 300-400 Watts you're looking at. On the one hand, using the "excess" solar is very satisfying, but on the other, having the water heater on the inverter circuit does require some thoughtfulness when using plug-in appliances that use a lot of electricity.
We'll often reach FLOAT state pretty early in the day, depending on where we are, and will have several hours of hot water generation, so it's worth it to us. If it were going to be much less than that, I'm not sure it would be worth the hassle--to me.
But it can be done.
time2roll
LipschitzWrath
Harvey51 wrote:
Anyone got an explanation for what Ontario Hydro does when itโ€™s heavily subsidized solar panels produce too much power? They give it to their good neighbours in the northern states, and sometimes pay those power companies to take it. I suspect it is due to deals made by politicians that require the utility to buy all the solar power available at prices 5 to 10 times the cost of other power sources. Electricity behaves logically but politics often doesnโ€™t.
Pretty darn close for a guess. I forget the name of the act down here in the States but it basically states that anyone who wants to put generation on the grid cannot be denied from doing so. This, coupled with the tax credits/subsidies, winds up placing large surpluses of energy on the grid at times when wind blows and sun shines.
Because they are getting a tax credit, if you tell them to shut off their solar/wind, they tell you to stuff it, because they're getting paid $38/MWh for the energy they're producing, even though nobody needs it. So then they sell the energy for near-zero or even negative prices and still make money.
This places the burden on other generation facilities (mainly thermal) to "regulate" the grid, which is basically balancing load and supply. In return, they can purchase this surplus energy for a fraction of what it costs them to generate and save their customers money. An added benefit is that they don't have to burn coal/gas to do it which reduces emissions and also reduces chemical costs, etc.
We do this in our fleet on a daily basis. It all falls under the umbrella of what is called an "Energy Imbalance Market" or EIM. The more people you have participating, the more money there is to be "made". "Made" is in quotes because for a regulated utility, you don't "make" any money. You are really saving money, and these savings are passed back to the customer in the form of lower net power costs.
In a sense, it's win-win, unless you're the American taxpayer that's paying for the subsidies.
pianotuna
Nomad II
Nomad II
nice link red31
Regards, Don
red31
Harvey51
As for the question in the first post, the mechanism is that a tiny flow of current into a full battery runs the battery voltage up to match the charging voltage. Since a voltage difference is required for current to flow, it doesnโ€™t.
LipschitzWrath
jolooote wrote:
Have you ever wondered why, as our electric usage in our homes and businesses gets more efficient using less Watts, our electric bill gets more expensive? The power generator( Power Company) must generate the POWER regardless of whether or not its used. As for u'r local Power Co. they have the same cost of production but less income as less power being not used is also Not paid for. As for we campers, we are the producers and always must pay for it. lol
I just gotta dogpile here. I am the Superintendent of Operations at a large power plant in Wyoming. Each of our 4 units has a nameplate rating of 530 megawatts. As I type this, our 4 units are generating:
U1 = 394 MW
U2 = 400 MW
U3 = 419 MW
U4 = 221 MW
Why aren't they at full load? According to you, they should be, and we should be charging our customers to do it. Ironically, the reason we aren't at full load is because our customers don't need the power.
And right in line with this discussion, one of the major reasons we are down on load during the day anymore is from a large increase in solar generation being put on the grid (both large generation facilities and individual rooftop solar installations).
As the sun comes up, we come down. With subsidies, solar is cheaper. But you can't make power with solar when the sun doesn't shine. You can, however, burn more coal.
Lest you forget, most power companies are regulated utilities. I can assure you 100% that a state's public utilities commission would never allow us to charge customers for energy they don't use or need. Another poster hit the nail on the head, you are charged for the electricity you use, nothing more, nothing less.
As for why your power bill goes up over time, well that's a different story. Inflation is one reason. Federal regulations requiring increasingly expensive pollution control equipment to be installed on units is another one. You don't honestly believe the power company just absorbs the cost when a $150 million SCR is mandated to be installed, do you? You, the customer, pay for it.
AllegroD
When you can mo longer absorb more power, the extra power goes "away"!
