I suppose it works, but so would a roll of paper towels, or something similar to a sun dial. It's plastic, sooner or later, will it crack or break, or the clamps fail?
Easier to just look at the shadow your solar panel is casting and call it good.
I use a staggered block out of 2x8" that I'd back my trailer up on if getting a flat tire, to roughly adjust my solar panel. It provides plenty rough enough adjustments for up and down of the sun in the winter time in the desert. In the summer, the panel gets only slightly elevated on the green astroturf scrap.
![](http://img.photobucket.com/albums/v374/grand_toots/2012%20Palomino%20Gazelle%20G210/20160121_104236_zpsrfpwe21t.jpg)
The price of that is $10, probably plus shipping, call it close to $20. Spend the $20 on more watts on your solar panel instead. Much better return on the $20 spent, more amps, makes aiming less critical. For you, a good 140 watt Poly crystalline solar panel should cover your basic recharging needs quite handily, if you are running LED lights inside, and being only a little bit conservative in your electricity usage daily.
I had a 120 watt monocrystalline portable... it's fine from spring, summer and almost fall recharging, but was coming up short camping in the short days of winter in the desert southwest. So I went to a 150 watt Poly crystalline solar panel, shown in the picture. Difference at all times, in terms of output in amps, low light, high sirrus clouds, etc, is superior with the poly crystalline panel, for my needs.
