Throttle non-responsive after batter disconnect
wcaswell
I have a 2006 Winnebago with a Ford 450 platform. It's a v10 gasoline engine. The battery died so I disconnected it and recharged it. After reconnecting, the engine starts fine, but will but rev past 1000 rpm. The throttle is non-responsive.
20 REPLIES 20
wcaswell
OK. Problem solved. When the throttle body as replaced, the air intake hood was not completely attached. Attached it firmly and all codes clear and engine runs perfectly.
Gdetrailer
wcaswell wrote:
Update #2. Replaced the Throttle Body. The engine now has throttle! Codes cleared. Now getting codes 2195, 2197 which indicate a bad passenger side O2 sensor forward of the Catalytic Converter. Replaced it, cycled the PCM, but still getting those two codes and rough idle and low power. It's drivable. We'll put some miles on it this weekend and see how it goes, then into the shop. Could be a vacuum issue.
Check the PCV line for cracks, that is a typical problem on the Modular engines, plastic gets brittle and breaks.
While you are at it, go ahead and change the driver side front O2 sensor, it is most likely not far behind in failing.
The front or upstream O2 sensors are the ones that the ECU uses to monitor and adjust the fuel mixture and are critical for correct engine operation..
The rear or Downstream O2 sensors are mainly for monitoring the efficiency level of the Cats (IE for emissions purposes) and are not critical.
wcaswell
Gdetrailer
wcaswell wrote:
Here's an update. I bought an Innova Code Hammer OBD2 Tool. It read codes P2112, P2104 and P2111. I disconnected the air intake hoses to access the throttle and cleaned it with Throttle cleaner, giving it a wipe down and manually manipulating the throttle gates to ensure they were not stuck. Then cleared the codes and ran the engine. Codes P2112 and P2104 reappeared and the throttle is still non-responsive. Next step is to replace the throttle body.
Did you try to recalibrate the throttle body to ECM?
Here is a Youtube video of the sequence..
Recalibrate Throttle Body Video
This step will reteach the closed through open values to the ECM..
Barring that, not sure if manually moving the throttle plate was a good idea. The correct way to clean the throttle body is to use the key on but engine not started and then have someone hold the foot feed down to the floor (which opens the throttle plate).
IF your code reader is able to read LIVE DATA, you should be able to read the ECMs TP values from closed to open with key on and engine not running. If TP values change then it just may need the calibration sequence done..
IF you do go with a new throttle body, chances are you WILL need to do the calibration anyways so I would do that BEFORE committing to a new throttle body (remember it WAS working before the battery was removed)..
MEXICOWANDERER
Is there a resistance test across the throttle body terminals?
A note about Mother Fletcher's Do it Yourself Megawatt Defibrillation -
When I told the cardiologist in Scripps what I did, his mouth kept opening and closing but nothing came out. The RN was also present, and after he exited post haste she quipped "I've never seen him do that before". But the ER doc who did triage visited and said "What you did took some nerve. Were you blacking out?" I replied to the affirmative. He gave me a thumbs up. I went into ventricular flutter the next night and they wheeled in the defibrillator. I took one look and grabbed the big patch that was already on my chest. I guess it scared me so bad I went back into sinus rhythm. The next day came the catheter ablation. The "Code Blue 506" also contributed to my fear.
MEXICOWANDERER
So!
It is not possible to ISOLATE the memory of an ECU? Oh stupid me, I asssssssssumed the circuits use 5 FIVE Volts instead of 12. Kinda improbable for 5 volts to jump backward through a power supply to the battery cables?
Maybe I am missing something here? Oh pullleease elaborate...
Maybe I should add ๐Ÿ™‚ ๐Ÿ™‚ ๐Ÿ™‚ ๐Ÿ™‚
wcaswell
Gdetrailer
MEXICOWANDERER wrote:
The geniuses could design the ECU to employ use a super-cap. If a positive cable should touch negative during a disconnect say adios to the memory backup. A supercap could power the volatiles for how long? Regardless of cause of power failure.
:R
Imagine what would happen with the first "super genius" back yard mechanic that accidentally shorted the battery terminals with a super cap attached to the ECU..
Even IF there was a super cap placed in the ECU, it WOULD have to be designed with at least a blocking diode to prevent heart stopping lightning and thunder from happening in case of accidental shorts..
Not everyone will want to own their own heart defibrillator in their car..
MEXICOWANDERER
wa8yxm
That "Memory Saver" is still made, You can get one at ______ auto parts (Fill in the blank with your favorite auto parts store.. Even some Department stores may have it in the Auto dept). I had a mechanic leave one in my car once (I returned it to him).
Very handy
On the motor home I have a different way to do it.
Gdetrailer
Computers have batteries. Now how great of capacity would it take to transfer RAM files to PROM status when a disconnect is sensed? Wait! That's too easy. Jeeze a super cap could power this action. Common sense ECU design will be eventually be "discovered" in the Far East8
Actually, Fords ECU does that one better..
They do have "volatile" and "NON volatile" memory..
Cutting the battery loose for even overnight DOES NOT ALWAYS CLEAR ALL "CODES"..
If a code is severe enough it CAN be stored in non volatile memory and will pop up as soon as you reconnect the battery.
As far as keeping all engine parameters "saved", that is AN EASY FIX.
Take a SECOND 12V battery (can be anything from a small 12V gel cell or even another car battery) and CONNECT it to the vehicles battery terminals BEFORE disconnecting the old battery.
There used to be a little device which plugged into a cig lighter jack of your vehicle which had a 9V transistor radio battery and a diode that was touted to keep your engine computer settings.. Not sure if a 9V battery could do that but anything close to 12V should do the trick (eight AA dry cell batteries with a diode could possibly work, note, diode is there to protect the non rechargeable dry cells from turning into little fire crackers!).
I HAVE done the 12V battery trick multiple times on my own vehicles, works every time!
MEXICOWANDERER
wnjj
Some ideas here for a similar year Ford product. Not a V10 but possible one of the suggestions may help.
baker01
Found this 2006 V10 procedure for you
A dirty throttle body can cause a low idle condition after disconnecting the battery. The engine computer will "learn" a new idle position over time as deposits build on the throttle body. When you disconnect the battery this memory is lost. The computer should relearn the idle speed fairly quickly. To help it along try the following: Warm the engine (hold the idle up with the gas pedal if necessary). When the engine is warm slowly release the throttle until the engine will idle on its own, let it do do for about one minute. Next with your foot on the brake place the transmission into drive and let the engine idle for another minute. Next with the trans in drive turn the a/c on for another minute. If this procedure does not restore the correct idle for your 2006 Ford F-250 Super Duty you can try cleaning the throttle body deposits by spraying some carb cleaner on a rag and wiping the throttle bore.
Dusty & Mikki
Sirverado 3500 Dually 4x4
2019 Fuzion 369
2018 XPT
2006 Honda CRF450X
2006 Rhino 660
Harley FXSTC
