Tire issue
rving4us
I need some thoughts on a tire issue. I have G 114 17.5 tires on my fifthwheel. they are 3 yrs old. I m adamant about checking tire pressure before each trip. Notice when we stopped today the front curb side tire is cupping on both sides of the tire about every 2 inches. The other 3 look perfect and according to my tire monitors all temp and pressure are within 1-3 lbs of each other. I also have the morRyde RE suspension if that helps. What could be causing this on 1 tire. Thanks
2014 Ram,4x4,dually,CC, Cummins, Aisin Trans, 4:10 rears
2011 Carriage Cameo37ks3,17.5 tires,disc brakes,full body paint.
10 REPLIES 10
ReneeG
If after a spin test, checking for out of balance condition, and replacement - if it happens again, check if your rig is out of alignment. We had that condition for two years in a row. Our RV tech recommended a local shop to check alignment after replacing the hangars, U bolts, and replacing the Equa Flex suspension parts; he was right. We were out by 1/4" and that's a lot. The alignment check was about $250 but well worth it.
Every year we take our FW to the tire shop and have them to a spin test and inspect all the tires. So far so good after new tires in 2014 and fixing the above issues.
2011 Bighorn 3055RL, 2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3, 1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica, Mabel, and Melton
rving4us
Thanks everyone.
fj12ryder
Take it to the dealer, it doesn't sound good, and it's unlikely to heal itself. ๐Ÿ™‚ Might as well get it replaced before it totally goes south on you.
I agree it is probably out of balance, but might check the brake and make sure you don't have a sticking brake or sketchy bearing.
Howard and Peggy
"Don't Panic"
MEXICOWANDERER
I would spin check all tires. Even if the tire checks correct (!) replace it.
Dennis12
Do what 2oldman said.
Dennis Hoppert
rving4us
for the ones that asked it is a Goodyear G-114. and it is cupping on the tread. ( not side wall)
Tom_N
I agree with out of balance.
Sarver, PA/Crystal River, FL/Shelocta, PA ยท W3TLN ยท FMCA 335149 ยท Mystic Knights of the Sea
2005 Suncruiser 38R ยท W24 chassis, no chassis mods needed ยท 2013 Honda Accord EX-L ยท 2008 Honda Odyssey EX-L
ReneeG
Could be out of balance. Being out of balance can cause one tire to wear differently than the others. How do I know? It's happened to us.
fj12ryder
Are you referring to cupping on the actual sidewall of the tire? Or cupping on the tread area of the tire? Got a photo or two?
Howard and Peggy
"Don't Panic"
2oldman
What brand of tire?
Tire cupping
