Thanks guys for the comments... I have pretty much put all of that to bed now for adding additional slots required.
I imagine the only other mod I might do is get a couple of partitions in the center of the box to separate my two battery banks. I have seen a couple of them shown in TORKLIFT photos on-line but don't see them listed anywhere with a sale price.
I am going to paint up a couple of fitted pine boards to a wood base on the floor and to the metal stiffener piece provided with the battery case. I will slot the top portion of the wood panel on the edge so I can route DC CABLES into the free area where my 4-position switch will be located. I would really rather have the free area on one end of the battery case but that requires longer lengths of DC Cables. All cables have to be the same length to support the same DC Current being used to both battery groups. If I setup for two groups of 6VDC batteries I will only need one 4-position BLUE SEA sealed switch. If I setup for two groups of 12VDC Batteries I will need a total of three 4-position sealed switches like I am presently using.
I don't think having my Blue Sea switches on the battery case wall facing the trailer will be a problem...
Getting about ready to start drilling some TAP holes through the bottom of the battery case and the trailer frame tops.
Oh since I am going to add partitions I will have to cut the provided Battery Mat to fit the floor space. I am also going to add wood strip 1 x 1 1/2 strips to keep the batteries in their required positions on the floor. These will be separated for the largest battery I might be using (GP27s or GP31s). The GP31s will drastically cut down of my free pace in the center of the battery box..
I'm not all that keen on using the web straps to tie down the batteries. I guess that is going to work OK for me...
You think you are going to have alot of room to work with but when you start adding things up all that room goes away hehe...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
