Looking at adding small Extruded Aluminum Vent strips on each side of the two cable holes shown below to give more ventilation for battery gassing. I will be mounting four each batteries in the box
![](https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcQ26lSbdqnAaa4LpW-RRsFh3iqoDi0l2kc4cvqucea3Nhf65h2Y)
Torklift Image
I will have to cut small slots in the Battery Box wall in-line with the two round cable holes. I will also be mounting a PVC Electrical Box with three 1/2-inch Cable holes on the back side around the two cable cable holes..
Have looked high and low for these kinds of vents with ATTWOOD Venturi Boat Vents. They are however too long. I need something 2-inch wide and 6-7 Inches long. I have found some stamped out stainless steel covers but would rather have the Extruded Aluminum pieces...
![](https://cdn.shopify.com/s/files/1/1089/9364/products/1494-300_1024x1024.jpg?v=1452534748)
ATTWOOD Image
PERKO has these flat Stamped Stainless steel panels that are about 9-inches wide that should fit.
![](http://www.boatersland.com/images/img/pko0550dp0chr.jpg)
PERKO Image
Just curious if anyone has something different to use...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
