Feb-05-2017 03:31 PM
Feb-10-2017 12:13 PM
JRRNeiklot wrote:
I'm currently using a 15 amp battery charger until I get my solar panels mounted. So it should be okay to set it at 14.8?
Feb-10-2017 12:08 PM
Feb-10-2017 12:02 PM
Feb-10-2017 11:38 AM
Feb-10-2017 06:12 AM
CA Traveler wrote:
The very popular 24V panels with 60 cells are about 30V+. Parallel 60 cell panels do not match up very well with 24V batteries which need 29.6V for bulk charging. This is not analogous to 12V panels which are 36 cells and 18V for 14.8V bulk charging.
2 12V panels in series or 72 cell panels would be much better.
Feb-10-2017 06:08 AM
Feb-10-2017 05:42 AM
Feb-10-2017 04:54 AM
BFL13 wrote:
"as right now, even my Rogue can't handle all the 700W Solar."
Probably several ways to solve that by splitting the array and using two (don't have to be identical or as expensive) controllers in parallel on the battery bank.
Why not start a thread on that for yourself? Be fun for forum members to spend your money and renovate your rig. Probably get some good ideas too. 🙂
Feb-10-2017 04:35 AM
Feb-10-2017 04:21 AM
BFL13 wrote:
"Sounds very nice. And if I switched to a 24V system, my existing 700W of hi-V panels would prolly work well with a couple SC2030s and a Trimetric."
Doesn't the controller need the batts to be the same voltage as the panels, per PWM, no buck converter? You can do 24/24 or 12/12, but not 24/12.
You are allowed to have 24/24 in the rig if you can get 12v out of it all for running the 12v rig. (various options for that)
Feb-10-2017 04:10 AM
Almot wrote:brulaz wrote:
My Rogue (and PD charger) only does 2 stage.
But at least the Rogue allows me to set the amps cut-off for absorb stage as well as the time.
If this is the Rogue I know - it is a 3-stage controller.
Bulk - amps and volt rise, Absorb - volts are constant and amps are tapering slowly, and Float.
Feb-09-2017 05:45 PM
Feb-09-2017 05:26 PM
Feb-09-2017 05:17 PM
Feb-09-2017 05:00 PM
