Feb-05-2017 03:31 PM
Feb-26-2017 07:58 PM
Feb-26-2017 06:12 PM
JRRNeiklot wrote:
Ah, thanks. I changed it back to 2. I have a Renogy Tracer 4210 40 Amp MPPT Charge Controller. It does not have a state of charge indicator.
Feb-26-2017 05:50 PM
Feb-26-2017 04:55 PM
Feb-26-2017 04:06 PM
Feb-26-2017 03:52 PM
BFL13 wrote:JRRNeiklot wrote:
My battery bank is 360 AH, My setpoint voltage is 14.8, so what should my P2 setting be? The default was 2, but 2% of 360 is 7.2, so I changed it to 7. Is that correct?
Thanks.
You had them down to 1.8a at 14.5 you said, so obviously 7a is not full yet. What did you choose for P1 when your controller is set for 14.8? Have you confirmed by SG that they can get to Trojan's 100% SG spec?
Somebody who has that 2030 set-up should help here.
Feb-26-2017 03:38 PM
Thanks.
Feb-26-2017 03:29 PM
Feb-25-2017 11:17 AM
JRRNeiklot wrote:
I have my panels hooked up now. When I turn the solar on, I'm getting 20 amps in, then it slowly drops down to around 1.8 amps. Currently, it's sitting at 14.5 volts and 95% capacity. Is this normal?
Thanks.
Feb-25-2017 10:01 AM
Thanks.
Feb-25-2017 09:09 AM
Feb-11-2017 03:45 PM
JRRNeiklot wrote:
Charger goes to 15.2 or so. I have everything straightened out now. How often should I charge to this 15.2 threshold? I'm getting 12.8 volts at 100% SoC.
Thanks.
And thank you to everyone who offered advice. I'm learning as I go.
Feb-11-2017 03:43 PM
Thanks.
Feb-11-2017 02:19 PM
