Vent-free propane heaters at high elevation
Chillyrodent
I recently bought a cabin that is off-grid and at 7500' elevation. I have camped at high-elevations with a Mr. Heater that has an O2 sensor with no problems, but just heard that they don't operate well above 7000'.
My impression is that the problem is more frequent shut-off than at lower altitudes. Do you have experience with vent-free propane heaters at high altitudes? I don't want to subvert the low-oxygen sensor altogether.
5 REPLIES 5
Moderator
Moderator
Moderator
Moved from Lifestyle
rexlion
When the heaters run low on oxygen they don't burn as efficiently, which causes CO output to be greater than usual. Not cracking a window open for ventilation will do this, so it stands to reason that the thinner air at high elevation will have a similar effect. Be careful.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
2gypsies1
We have an Empire and it's been used at 9,000' and does well. We love it - such a warm steady heat unlike the furnace. Have used one for 16 years.
Full-Timed for 16 Years
.... Back in S&B Again
Semperfi_66
my Mr Heater at 8600 ft works fine
2016 Open Range 3X349 RLS
620 Watt Solar
2000 Inverter
2 8D Gell Cells
2016 Ram 3500 4X4 6.7 Cummins
HD Direct TV
Onan 5500 Generator
2016 Harley Ultra Limited
2016 Can Am Commander Limited Side by Side
Patriot Guard Rider
Jerrybo66
I used a Blue Flame 10,000 BTU heater at 6900+' that I guess didn't burn the gas thoroughly and it made my eyes water. A following trip, same elevation with a Wave,3 it burned clean but didn't put out the heat I expected. Not enough oxygen??? The Blue Flame works great in the toy hauler down here in the desert, (1300'). I now have a Mr. Buddy Heater for the next 7000' trip. Our Son has one and it worked well at that altitude. If that doesn't work for me I guess I'll be in the market for some good wool long johns...........
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
