โMar-30-2016 11:29 AM
โApr-01-2016 10:44 AM
โApr-01-2016 08:47 AM
2oldman wrote:
Hey.. I didn't write that! But, I do like monkey butts.
โApr-01-2016 07:46 AM
โMar-31-2016 09:22 PM
racer4 wrote:2oldman wrote:racer4 wrote:
Does anyone know of a good AGM that fits in a GC-2 foot print, has about 240AH capacity (4 batts total ~480AH @ 12V), and is easy to buy at a price that won't scare most people away.
Lifeline GPL-4CT batteries will give you 440 AH at 12 Vdc, but they're not cheap at $299 apiece.
Still, the best decision I ever made was to substitute Concord batteries (Mil-Std version of Lifeline AGMs) for the OEM Gill flooded cell batteries on my helicopters. Instead of replacing every 12-14 months, I was getting 5 years per battery. Even though the Concords cost nearly twice as much ($840 vs 475), I was coming out way ahead... not to mention eliminating maintenance downtime. When it came time to replace the two OEM Trojans on my Roadtrek, I didn't hesitate a second.
Powerstride had the best prices last year when I purchased my GPL-4CT-6s at $250 each (free S&H), but other sellers may be more competitive today.
โMar-31-2016 04:39 PM
โMar-31-2016 03:30 PM
2oldman wrote:racer4 wrote:Then you should consider AGM batteries, not just for that, but for the cleanliness and NO maintenance.
My primary objective is to finish a daily battery charge with the generators and the 100 amp converter in the shortest time practical.
โMar-31-2016 02:50 PM
racer4 wrote:
My primary objective is to finish a daily battery charge with the generators and the 100 amp converter in the shortest time practical. When boondocking, the residential refrigerator will use about 150AH (estimate) daily of battery capacity.
โMar-31-2016 11:48 AM
โMar-31-2016 06:11 AM
racer4 wrote:I believe your initial assumptions are a bit skewed and why wouldn't they be since your power use hasn't been documented or probably even been researched by the mfg of your RV, An owner is left to find out on his own and adjust electrical matters on his own.
OP here.
So I want to choose cables that will help with that daily charge and help the 200 watt (or 400 watt) solar panel(s) get the most AH into the batteries as is practical.
โMar-30-2016 09:05 PM
โMar-30-2016 08:47 PM
โMar-30-2016 08:24 PM
racer4 wrote:not the battery cables..no.
One more factor I forgot to say. The FW will also have a 200W solar panel factory installed (by Cedar Creek), which I am trying to have increased to 400W. Does that make a difference in choosing the cable size?
โMar-30-2016 08:08 PM
โMar-30-2016 07:45 PM
