โMar-21-2014 04:27 PM
โMar-22-2014 04:55 PM
โMar-22-2014 08:59 AM
โMar-22-2014 08:36 AM
โMar-22-2014 06:20 AM
โMar-22-2014 06:16 AM
โMar-21-2014 11:06 PM
โMar-21-2014 07:48 PM
โMar-21-2014 06:15 PM
โMar-21-2014 05:52 PM
โMar-21-2014 05:22 PM
โMar-21-2014 05:13 PM
OnaQuest wrote:X2 I had a bad connection between the cable end and the battery connector into which it was inserted.
If the battery ground cable was getting warm (hot) you can bet it has a bad connection at that point. Check the cable terminal ends where it enters the insulation. If you see any green oxidation, replace the cable.
โMar-21-2014 05:00 PM
โMar-21-2014 04:49 PM
โMar-21-2014 04:34 PM
Tom_M wrote:
Sounds like a bad ground connection. Disconnect your cables and clean the connections.
