water heater
cpaulsen
Sububran water will not ignite when on propane....electric portion works fine.....and yes...I do have propane
cpaulsen
21 REPLIES 21
wa8yxm
rk911 wrote:
will the stove light? if so let the burners burn for about 30-seconds and try again. you may have air in the line.
I keep hearing this but frankly.. Think about it. Stove sips propane. Water heater guzzles it. (Same for Furnace) Water heater will try 3 times before it locks out.. You'd need like 100 feet of line full of air or more before the first two attempts would not purge.
But that said.. Won't hurt to light the stove as that confirms the propane system is indeed working.
To the O/P. You need to observe while someone else turns it on.
Does it light, go out re-light (three times no relight the 3rd time)
Does the thing make sparks (Snap SNap) but no ignition
Does it just sit there like it was turned off.
Once we know that we can get more specific.
RickLight
There was a bad run of controller boards. Get a dealer to check your board and install a replacement. (30 min job all told) A good shop will do all the warranty paperwork for you. (Thanks Xtreme RV Idaho)
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 CC SB Lariat Powerstroke
PullRite Superglide
doxiemom11
Ours is an Atwood, but exactly the same problem - wouldn't light on gas, worked fine on electric. It was the circuit board on ours.
Lwiddis
rk911’s suggestion is spot on.
rk911
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
BFL13
Did you try to reset the 12v Tstat?
Does the red light by the switch come on and just stay on, or does it not come on at all?
Does your digital voltmeter say the switch is getting 12v at all? If yes, is it getting to the circuit board? (Jumper the wires by-passing the switch to see if it is the switch failing to make the connection--if so get anew switch)
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
MDKMDK
Batteries enabled?
Usually need 12VDC power for w/h operation. For control board and DSI.
Other propane appliances working?
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
