Water Pump Being Weird. Is it dead?
jorn
My pump is being weird.
I've charged the water lines via city water, and all is well. No leaks detected. But when I try to run the pump off a full water tank, it seems to struggle a bit. When I open a faucet, I do get water, but at sporadic pressure and with intermittent air. When I shut off the faucet, it cam take up to 10 seconds for the pressure to return enough for the pump to set off. Or, it can take several minutes! Once it does, it never comes back on, so I highly doubt a leak is to blame.
Is this the sign of a dying pump? (It shows a 2015 manufacturing date.)
Thanks!
'16 Chaparral 360IBL & '16 Ram 2500 Cummins
19 REPLIES 19
midnightsadie
sounds like your getting a bit of air when it sits, pull out re check .figure out where that shot of air is getting in.
craig7h
Nomad II
Nomad II
Have you cleaned the sediment screen on the pump?
Itasca Meridian SE 36g
Road Master Tow Dolly
wnjj
Except when you can't find the parts, or they cost half the price of a new pump.
It can't hurt to take it apart and make sure there's nothing caught in the valves. Being that new it's unlikely to be failing outright.
cavie
cavie wrote:
Pumps are very much rebuild-able and easy to do. Amazon is your friend.
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
cavie
Pump are very much rebuild-able and easy to do. Amazon is your friend.
