โJan-26-2018 07:07 AM
โJan-27-2018 08:58 AM
โJan-27-2018 07:02 AM
โJan-27-2018 06:52 AM
โJan-27-2018 06:38 AM
AlwaysDreaming wrote:
As you can see in the photo (which is side ways unfortunately) in the link in the first post, it looks like it is leaking from the center not from the spin welded flange. Here is a link to a picture of the spin weld sensor that is used:
https://www.rvupgradestore.com/RV-Holding-Tank-1-Spin-Weld-Sensor-p/10-1697.htm
It doesn't need a grommet because the screw doesn't protrude into the tank. In other words, even with the screw removed it should not leak. Am I right?
I think the spin weld sensor is leaking between the metal probe sensor and the plastic weld flange? I think when I try to tighten or loosen the the screw the metal probe sensor is twisting as well?
Do you think LeakSeal flexible rubber coating would stop the leak if I sprayed it on the screw and probe in the middle of the spin weld sensor? , has anybody ever used it?
Thanks
โJan-27-2018 05:56 AM
โJan-26-2018 06:47 PM
โJan-26-2018 05:13 PM
โJan-26-2018 05:04 PM
โJan-26-2018 03:02 PM
โJan-26-2018 03:00 PM
โJan-26-2018 12:12 PM
โJan-26-2018 11:44 AM
โJan-26-2018 09:39 AM
โJan-26-2018 08:08 AM
