โOct-29-2014 10:25 AM
โNov-04-2014 12:36 PM
โNov-04-2014 11:21 AM
โNov-04-2014 09:32 AM
โNov-04-2014 08:50 AM
โNov-04-2014 07:57 AM
โNov-03-2014 06:20 PM
Salvo wrote:
This person seems to believe it works as a mppt controller.
Qianqs controller
โNov-03-2014 05:23 PM
โNov-03-2014 04:42 PM
Salvo wrote:
Here's a mppt controller for $48 including shipping. Voc = 75V
Qianqsun mppt
For $48 you can go serial, keep your existing cable and just swap out the controller. In addition you'll get 5% more current.BFL13 wrote:
The $102 Eco-Worthy 20amp MPPT is the lowest cost "real" MPPT but it can only do about 42-45 Voc input limit, so it can do one big panel (250w max?) but not two 12v panels in series. (22 +22=44)
So the money does not work out for going MPPT in this case just to be able to use some skinnier wire.
โNov-03-2014 03:59 PM
โNov-01-2014 04:59 PM
Keith Haw wrote:pianotuna wrote:
Hi,
#10 will be just fine with a pwm controller. I would add a temperature sensor.
Hate to sound stupid but, where would I find a temp sensor and where would I connect it?
Thanks
Keith
โNov-01-2014 03:45 PM
Keith Haw wrote:Some controllers have a connector for the temp probe and it may be an additional item to purchase. The probe end is attached to a battery post or glued to the case.pianotuna wrote:
Hi,
Thanks
Keith
โNov-01-2014 01:26 PM
pianotuna wrote:
Hi,
โOct-31-2014 04:53 PM
pianotuna wrote:
Hi Salvo,
You know that pwm doesn't control voltage so the top 2.6 volts on a 17 volt panel don't matter a hoot, assuming a 14.4 charging voltage. #10 wire is good for 30 amps. 280 watts/12.8 volts =~22 amps max.
โOct-31-2014 04:48 PM
