โDec-23-2017 08:06 AM
โDec-25-2017 05:52 PM
โDec-25-2017 04:27 PM
pnichols wrote:MEXICOWANDERER wrote:
With a new hole in wood I use silicone grease on the fastener threads.
There's something better than messing with silicone to make screws drive into wood easy: Just use a bar of soap that you have wetted with water. Rub the screw back a forth against the slippery soap bar surface to pack some of the wet, soft soap into the screw's threads. Wa La - the screw goes right in using even a hand screwdriver, and .... it doesn't make much difference what kind of head the screw has.
By the way, the best way to remove old screws that are really stuck in regardless of what kind of dumb, easily stripped, head type they may have is to use ... a reversible "impact" electric drill (NOT a "hammer" electric drill). I've removed an uncountable number of 3 to 4 inch deck screws in old wood using one of greatest inventions of all time -> an electric impact drill in reverse mode ... it's magic.
โDec-25-2017 02:31 PM
Bill.Satellite wrote:
I have heard of Torx head but what is Torex?
โDec-25-2017 01:17 PM
โDec-25-2017 09:32 AM
โDec-25-2017 09:18 AM
โDec-25-2017 08:08 AM
wa8yxm wrote:
Some of them.. Well there is a story as to why I had to replace an engine (It was a case of MURDER, not a natural death).. Well there are now two blocks of wood, held in place with Stainless Torex, that should the thing that currently just sit there. Doing nothing but get inspected from time to time.
But should the incident that Killed engine #1 ever happen againk those blocks of wood will spring into action and prevent a disaster.
โDec-25-2017 06:12 AM
Living in salt air, I use stainless fasteners for electrical and wood. The definition of misery is to use a phillips type stainless steel fastener. Even extremely expensive 316 grade is no match for a hardware store grade 2 screw when it comes to strength and ability to defend against damaging the cross. But Robertson screws can tolerate tightness all the way up to snapping off the threads (Canadian word coming) whilst surviving high driving forces in the head.
โDec-24-2017 06:33 PM
โDec-24-2017 09:03 AM
โDec-24-2017 08:55 AM
โDec-24-2017 08:23 AM
โDec-24-2017 07:40 AM
โDec-24-2017 06:46 AM
