โAug-28-2018 04:45 PM
โAug-28-2018 06:38 PM
dougrainer wrote:BFL13 wrote:
Disconnect the house batteries entirely. The Magnum charger should make your 12v just fine. If still having problems, it will be possible to trouble shoot that.
A bad battery might create problems for the charger in the inverter/charger. Your symptoms suggest another problem though.
You only need house batteries if you need to survive periods with loss of shore power and go onto inverter for 120v and battery for 12v (including the inverter)
You could be having shore power problems or transfer switch problems. Disconnect house batteries to remove them as a "distraction" for going trouble shooting, since they don't even need to be there right now.
YOU NEVER OPERATE AN INVERTER/CHARGER WITH NO BATTERIES. BATTERIES ARE REQUIRED FOR THE INVERTER/CHARGER TO FUNCTION. BAD BATTERIES WILL CAUSE SOME INVERTER/CHARGERS TO MALFUNCTION. BUT IT IS RARE, IT USUALLY JUST ALLOWS MINIMUM 12 VOLT POWER TO THE RV. Doug
PS, Some Inverter/Chargers will not even power up without a battery(good or bad) connected.
โAug-28-2018 06:31 PM
โAug-28-2018 06:26 PM
โAug-28-2018 05:05 PM
โAug-28-2018 05:03 PM
