wind sensor 2001 monaco
klutchdust
The latest issue is the two cup wind sensor for the awning . Well one side broke off and owner would like it repaired. Is the plastic cup" twirly thing "replaceable, the awning is a girard. my search hasn't come up with
much.
I have seen replacement cups, some have three. Will that change the sensor reading/ speed reading? We can fabricate anything to make it work if that is an issue.
4 REPLIES 4
Ivylog
I did much the same as Twomed but in less than six months it came off somewhere. I bough this recently but have not put it on yet. There is an adjustment on the board to set at how much wind it comes in.
Upgraded with a 08 HR Navigator 45โ€™...
Twomed
Girard wind sensor wind cups. Just bought replacement wind cups from LaCrosse Technology at service@lacrossetechnologyoutlet.com for $9.95 + $3.09 fgt. = $13.04 LaCrosse Technology at service@lacrossetechnologyoutlet.com for $9.95 + $3.09 fgt. = $13.04 Beats Girard replacement price of $142.00.
Old sensor cups are on a splined shaft which can be removed with wide blade screwdrive on one side and fingers on other to pull up and off.
The replacement is a "WS-2010-15 Cups G1" from above. Had to drill new sensor hole larger with 9/64" drill and then just press. ๐Ÿ™‚
Much cheaper fix
From BAC website ๐Ÿ™‚ ๐Ÿ™‚
Happy Trails ๐Ÿ™‚
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
klutchdust
Altern wrote:
Girard is located nearby in San Clemente.
Give then a call: http://www.girardrv.com/rv/
great, thanks
Altern
Google says Girard is located nearby in San Clemente.
Give them a call: http://www.girardrv.com/rv/
