โNov-13-2013 02:41 PM
โNov-15-2013 02:20 AM
Lantley wrote:GENECOP wrote:
http://beamalarm.com/foretravel-links/PDF/no-fuss-flush.pdf
Unless I missed it.
I see no mention of winterising procedures in those instructions.
I also see no mention of fall or putting any pitch on the piping?
โNov-14-2013 04:30 PM
โNov-14-2013 02:48 PM
โNov-14-2013 02:42 PM
Bumpyroad wrote:GENECOP wrote:Bumpyroad wrote:GENECOP wrote:
http://www.campingworld.com/shopping/item/no-fuss-flush/3495
yep but you also need the installation kit, hose, bracket mount, etc. the accessible location on my black tanks has been at the outlet area and you want the flush mounted on the side opposite it.
bumpy
We Have a Truck Conversion Class 8 MH.....MY HOLDING tanks are in an enclosed heated compartment behind a lower door, my NF Flush was easy to install and easily accessible for hooking up the hose ......Top of the tank on the same side as the outlet so the spray hits the back wall and sides of tank and washes everything out nicely....
that installation is directly opposite of the recommended one. would be better on the side opposite the drain to push stuff out and to break up the pyramid under the stool. I sort of gave up the idea of installing one on my new TT since the side opposite is buried. may look into installing one adjacent to the drain:????
bumpy
โNov-14-2013 01:16 PM
bumpy
โNov-14-2013 12:30 PM
bumpy
โNov-14-2013 11:31 AM
โNov-14-2013 11:30 AM
GENECOP wrote:Lantley wrote:
Exactly Bumpy,
the physics maybe at work but I don't know if there is a quality controlled building process to go along with it.
I don't think the builders put any effort into ensuring the hoses are supported and angled to ensure all water drains out.
In the end its the luck of the draw and a gamble.
Blowing lines will be very beneficial. The pink stuff is foolproof.
I think the confusion here lies in the type of black tank flush system, I installed my own NO FUSS FLUSH......it has no pipes, check valves etc....it's just a 2-1/2" long stub that gets mounted on the side of your holding tanks, hose connection at one end, several small holes on the interior of tank side......there is no place for water to collect.....
โNov-14-2013 09:49 AM
โNov-14-2013 09:46 AM
Lantley wrote:
Exactly Bumpy,
โNov-14-2013 02:20 AM
โNov-14-2013 01:42 AM
You guys who do nothing are trusting the build quality and the precise critical standards that go into every RV
No just trusting physics....
โNov-14-2013 12:30 AM
โNov-13-2013 06:38 PM
Lantley wrote:
Blowing out should be sufficient, however I can easily pump antifreeze into the black tank flushers using my outside faucet via the convenience center.
