I have a Xantrex Prosine 2000 and am having trouble with the charge function
when batteries are below about 70% SOC using a Honda 2000 generator. I think the inrush current is causing the problem. The generator does not trip but I loose all 120 volt AC to the trailer. It resets and faults again over and over.
If I hook 2 Hondas together for a total of 4000 watts available it works fine and then I can turn one generator off. Sometimes it will work with 1 2000 watt generator but takes a few tries.
I want to be able to use 1 Honda 2000 watt generator to charge batteries.
I think charger pulls too many amps for a few seconds and lowers voltage to a point that the charger senses it and trips off.
again generator never trips from overload.
any help??
thanks
2018 D/A crew cab standard bed,
2004 Hitchhiker 5th wheel, Dexter/Titan Disc brakes, EZ Flex wet-bolt, CRE 3000 center link suspension, B&W hitch, 5Th Airborne sidewinder pin box.
