โOct-30-2023 11:02 AM
โNov-06-2023 10:39 AM
โNov-02-2023 12:30 PM
โNov-01-2023 06:07 AM
valhalla360 wrote:
Might check the wiring near the trailer plug. If there is a short, it may have closed the circuit that the truck checks to determine if a trailer is attached but not all the circuits check out, so it gives you a warning. Particularly if the issue is intermittent.
When the trailer is hooked up, all the circuits connect, so it thinks things are fine and enough juice may be getting back to operate the trailer brakes...so the warning goes away and your brakes work.
Had an issue with our ford where the wire to one of the trailer brakes was chaffed and a strand was intermittently hitting the frame setting off a similar issue.
โOct-31-2023 07:07 AM
โOct-31-2023 06:01 AM
Home Skillet wrote:
Check for corrosion inside the back of the trailer connector, on the vehicle side.
โOct-31-2023 06:00 AM
ktmrfs wrote:
if it is like the silverado, highly likely the problem is the manual trailer brake control lever on the dash. easy peasy to replace and often fixes the problem.
โOct-30-2023 09:11 PM
โOct-30-2023 06:32 PM
