'14 ram 2500 loses the leafs
jbardram
Didn't see this posted anywhere yet. In the release about the 6.4 hemi it mentions the 2500 will have the same rear suspension setup as the 1500 without losing any capacity. Bold and what I think is a smart move by ram. Will certainly better differentiate the 2500 from 3500 as has been often discussed here. They are making an aggressive play for market share with quite a few firsts of late (8spd, LD diesel, air suspension etc)...
http://www.allpar.com/news/index.php/2013/06/ram-hd-6-4-official
09 Chevy 2500hd 3.73 6.0 CC
05 Wildwood 27' TT
17 REPLIES 17
larry_barnhart
if a new Ram can haul or tow 30,000 lbs how can it not be on the stiff side?
Just asking not telling.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
FishOnOne
The new front suspension should have been installed on the 2500 '13 models as well. The bone jarring ride of the current 4 link front suspension is one of the reasons I ran away from purchasing a RAM.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
45Ricochet
I read about it yesterday and I found the air bags on the 3500 interesting also. I was wondering if the 2014 MY are going to use softer leaf springs for ride comfort when not towing, and air up the bags for heavy loads. I frankly don't understand adding air bags to a 3500 DRW unless something changed from the 2013 springs.
LOL on edit
I should have read your link first. Yes softer springs. I'm certainly glad they had the hitch adapter problem which resulted in me waiting till next spring to buy a new truck :B
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
