2002 Duramax fuel leak
snowpeke
My 02 Duramax at 80,000 miles started leaking fuel under the motor, anybody have that prolobem. Looks like it's going in the shop.
2002 Chevy DuraMax
2014 jayco eagle
Two Pekingese dogs
3 REPLIES 3
lazydays
Check your fuel rail on that side and injector connections. My driver side fuel rail leaked about 4 years ago. Had to have it replaced.
Very Patient Wife
Two Boys & a Girl
2013 Keystone Avalanche 345TG
2016 Chevrolet Silverado 3500HD 6.6L
snowpeke
The leak not around the fuel filter. The leak is underneath, coming out of a 3/8 plastic hole on the right side.
2002 Chevy DuraMax
2014 jayco eagle
Two Pekingese dogs
98silvz71
Where exactly is it leaking from? I know that if you haven't done it already, the fuel filter head seals wear out and it will start leaking from there. The fuel filter is located on the passenger side, just under the intake tube. If you have fuel in that area, it is most likely that leaking. I have already done this repair on 3 Duramax's. 2 LLY's (04.5 - 05) and 1 LBZ (06 - 07) trucks. Only 2 of them had problems with losing prime, where you would have to pump it up to the filter head again to get the truck started.
2013 Chevy Silverado 2500HD CC/SB Duramax - 20K B&W Companion, Bilstein 5100 Series Shocks and Stabilizer, BFG A/T KO2
2014 Keystone Fuzion 342 Toyhauler
2008 Arctic Cat 700 Diesel
