2008 2500 gmc diesel
boot_scooter
Need to know what the weight spec,s are for a 2008 2500 GMC diesel extended cap truck is. Thank you for your reply.
3 REPLIES 3
Roger10378
My 2007 should be identical so here are the numbers for it. GVWR 9200. Frt. axle 4800. Rear Axle 6084. I scaled at Frt. 4225, Rear 3150, with the wife and I. It also included the hitch and other stuff ready to travel.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
1492
Moderator
Moderator
Moved from Forum Technical Support
KD4UPL
GVWR is 9,200. I think the front axle is around 4,500 and the rear around 6,500.
It's probably about 7,500 to 8,000 empty but that depends greatly on the options.
